81 - 83 of 83 Posts
I'm adding my experience to this thread because it is 'the one' that comes up in google searches. I think it is likely that most people are going to find these instructions when they search. I used the written instructions on the first post here and everything went smooth for me. I did not watch any of the utube videos. I did mark my timing chain and cam gears using a silver sharpie after wipping off the oil film, and counted 8 links on the chain between the marks I made. I didn't have any trouble putting things back together - getting the timing marks lined up was a little fiddly and I used a 10mm wrench on one of the cam gear bolts to be able to rotate the 'intake' cam one tooth forward towards the exhaust side in order to get everything lined up properly. I noted that 'before' the cam chain tensioner is installed both cam marks were off a little bit (maybe 1/2 to 3/4 of a tooth) towards the exhaust side of the motor, once the cam caps are installed and the tensioner was installed it pulled everything tight and all marks alligned.
I used the following shim calculator that I found with a google search - worked great:
Note that on an XSR you'll have to remove the right (throttle) side wire cover thing that is between the tank and the steering neck. The plug for the radiator fan is up under that cover - you'll need a 12mm wrench and a hex key.
Two small tips:
1. install the lower airbox BEFORE you tilt the radiator back into place - makes it super easy to reach in and connect the PCV breather hose from the top of the valve cover to the bottom of the air box. It can be done the other way - but its a lot tighter reach.
2. Remove the valve cover BEFORE you remove the spark plugs, having the valve cover off reduces the ammount of extension you need to reach the spark plug and gives more clearance for your wrench. Install the new spark plugs just before you put the valve cover back, same reason.
My measurements at 27,000 MILES
81 - 83 of 83 Posts
