Today is valve clearance check day!!
This is the third check I've done on the bike, the first one being at 33,000 kms, second one at 67,000 kms.
I'm happy to report that the clearances literally have not changed. The numbers are still identical to the measurements of my first check at 33,000 kms.
Numbers are as follows:
EX #1 0.254, 0.267 #2 0.254, 0.279 #3 0.254, 0.267
IN #1 0.165, 0.178 #2 0.178, 0.165 #3 0.165, 0.152
Yes, some of the exhaust clearances are slightly out of tolerance on the tight side, but now knowing that they haven't changed over quite a long distance, I am not about to pull the cams to correct it.
