41 - 60 of 144 Posts
Just did mine too... i like it better.
And also took off the heat shield / cover thing...
(FYI, for the long bolt on the bottom, I just stacked a couple black nylon washers to fill the gap.)
I don't have my bike yet (Wednesday); So are there only 3 bolts, and only the lower one needs replacing or spacers? Does anyone know the specific torque?
It looks soooooooooo much better off
Decided to loose my right side cover. Think it looks way better without. i did notice a little more heat on my right foot when I ride so obviously that is one of the reasons its there. The other is it has a fork that holds and protects wires from the riders foot. i found a 3/8" insulated wire clamp at my local hardware store to hold the wires in a protected position. It looks the part too. ;)
Replaced three M6 (I think) bolts with a washer and shorter length as the originals are too long without the side cover. The cover has stand offs for the bolts. I can't recall the length I got but there 1 - 2 cm shorter.
"Decided to loose my right side cover. Think it looks way better without. i did notice a little more heat on my right foot when I ride so obviously that is one of the reasons its there. The other is it has a fork that holds and protects wires from the riders foot. i found a 3/8" insulated wire clamp at my local hardware store to hold the wires in a protected position. It looks the part too. ;)
Replaced three M6 (I think) bolts with a washer and shorter length as the originals are too long without the side cover. The cover has stand offs for the bolts. I can't recall the length I got but there 1 - 2 cm shorter."
This is great. Did you actually mean cm and not mm ? - forgive my ignorance! I'm very nervous about messing about with it but this is a must. I wonder if the FZ/MT cover (I wonder if that has a fork in it) would fit to alleviate the heat?
Thanks for the tips guys.
I got a hose clamp as per flyntigger's suggestion, and bought a shorter bolt from Yamaha, the same as the two shorter bolts you remove (item 22 on the parts diagram). The bolt was only a couple of dollars and if I change my mind I can just put the cover back on with the original bolt.
Well my 60th made it home!!! First one in Louisiana from what the dealer told me��. Well anyway haven't rode the bike yet due to bad weather...so covered the side cover and radiator guard with some carbon vynal. Can't wait to give it a GOooooooooo!
Gonna make some Tuning Forks Logo to go in the center....
Hand cut me a tuning fork logo...
