I need to remove the O2 sensor when I get my flashed ECU back. Where exactly is the connector under the tank? Anyone got a photo of the location?
Amazon, Ebay or the local auto parts store. It's a standard 18mm x 1.5 O2 plug.Where did you buy the plug?
Simple-ish routine. Undo the two allen screws holding the plastic case for the connector - they are attached to the engine case. Easy to get off and put back on after you have removed the o2 sensor.I'm only doing this because my ECU has now been flashed and O2 sensor disabled. If you do it to a stock bike, the AFR will constantly fluctuate.
Yeah, I disconnected it but left it in place.when the o2 sensor is disables with a flash it does not need to be removed from the bike
