81 - 100 of 144 Posts
How about only folks with apparent flaws in the frame post, the rest is drivel and garbage. Your mileage will vary.
Ride Safe.
Just because you have your thumb up your butt, doesn't make you a proctologist.
Ps, If your offended get over it.
Filed off edges? Man, I inspected the heck out of mine today, and cannot find any portion that is not silky smooth? Where are your filed edges? My frame appears flawless, it is very high quality, not a single mark in it... I'm actually really impressed!
I wonder if Yamaha switched up their casting supplier?
I would expect that Yamaha do all their own castings.After all,it was casting alloy piano frames that got them into vehicle manufacture.
The frame is most definitely die cast, not sand. Injection molding pertains to plastics. Either way, good on you for bringing it to their attention. Keep us posted.
Yamaha use controlled filling vacuum diecasting ,a technology they developed themselves.
A new die-cast method for manufacturing innovation "Yamaha CF Aluminum Die Casting Technology" Developed Making possible the mass production of large but thin aluminum die-cast parts - News Releases | YAMAHA MOTOR CO., LTD.
Mine is 4/14 build and has some minor up at steering neck and small one at middle triangle point but not at those 2 bolts...
Pics attached
I'm not worried about it.. Just think its casting marks. Will keep an eye on em though.
Pics attached
View attachment 15003 View attachment 15004 View attachment 15005
Those definitely look like casting flaws, not fractures. Probably just luck of the draw whether your parts were molded in a casting that has built up residual debris. That's my guess. Dirty castings in areas which have a higher chance of leaving behind material.
Agreed. A shame that they've gotten so ugly.
I went out last night and looked at my 14's frame and it's nice and smooth. I suspect, like others, that later frames are just suffering from dirty-casting-itis.
I owned a 1991 and later a 1993 Honda CB750. I remember the wheel castings on the 93' were not as clean as the 1st year bike's.
it's not just later production runs.
here's mine, build date 10/13:
when i first noticed this early last year, i took a look at a few other fresh out of the crate 09's. they all had identical imperfections in the same place.
i don't worry about it and in fact i'd forgotten completely about it until this thread.
p.s. the flaws can be hard to spot unless the light hits it just right. so those of you with 'perfect' castings, don't go looking too hard for them, you're bound to find some somewhere. that's just the nature of mass production.
