So, I know it's overfilled.
But I'm also running the Pure One filter that's slightly longer, so has slightly more volume.
And with 4 quarts of Rotella T Synthetic 5/40 oil, it's right in the middle of the two marks on the sight glass while the bike is on the kickstand.
Before that, Never saw any oil, since I don't see the oil sight while the bike is not on the kick stand... I'm too busy riding the bike.
Oil is not foaming. Looking at the crank position, don't see that oil is anywhere near the rotating crank, or even where I think the counter rotating weight is, but might pick up some extra oil in the transmission? (But again, it's going to go everywhere anytime you ride the bike, so it's not a problem I can see yet.)
Any thoughts?
I have found it shifts smoother.
Engine runs fine. Cam tensioner is not any more or less noisy than it was. And I have a longer bolt to limit how much it can "retract" the adjuster part, and that seems to be working fine. I measured it out, and used washers like shims to get the depth right with no noise, but not too tight.
Any thoughts?
