41 - 50 of 50 Posts
Screws DIN7991 will be great for this job. I had idea to use them too but couldn't find.
First, a big shout out to Korider for figuring out the source of the vibration. Thank you, Oleg! I ride a 2015 FJ that had the clutch vibes. I performed this mod yesterday and it's like a brand new bike, maybe even better. I saw the DIN 7991 screws come up so I went that route and just wanted to give a report on how it worked out. I drilled and tapped the posts on the clutch basket then I used a 5/8 countersink bit to bevel the cover plate holes and gave just a touch of countersink to each tapped hole so the screws could really set down in. Here's the result...
In my opinion it worked out great and I still have my full hex depth in each screw if I ever need to take it apart again. I hope this adds to the discussion and gives some folks more ideas on how they can tackle this job. If you've got the clutch rattle this is absolutely worth it.
Gentlemen, in last winter, I performed also the replacement of the dampers. At mine, there was also play between the gear and the basket (on the outside app. 2 mm on the circumfence).
I fitted also the Hinson rubbers, and I noticed that het Original ones has been chamfered, the Hinson not.
I made a aluminium tool for exact centering the rivets
As I wouldn't harm the back plate, after drilling I grinded a cross into the rivets.
And hammer them off by hand. This was my inspiration during removal :) https://www.youtube.com/watch?v=jflZJU2sEVI
As the hole is 6 mm in dia, and using the metric values (Netherlands :)), the next step was M8 and I decided that the aluminium material was not thick enough for M8 (I'm mechanical engineer, building machines). Grinding off screw heads is not a nice solution I think. So I chose to rivet it back together. A company which fixed car clutched did it for me, costs: 20 euro.
Hi Pmych,
Can you please share what is the length of the DIN 7991 bolts you went with? Thanks!
We obviously think alike. I had the same idea for centring tool for drilling out the rivets
Hey Oleg,
Great write up mate, thanks.
I have the 2017 MT09 and live in Australia.
I at looking to do the cushion kit upgrade as my clutch is making a hell of a racket.
Do you know if the Hinson CU216 kit would fit a 2017 MT09 with the slipper clutch?
Cheers John
Yesterday basket was installed and checked. Bike works perfect. Any vibrations,any noises. My bike have never works like that.
If something happen with dampers again, I do not need to buy new basket. Just buy new dampers,remove bolts and change them.
I done the same with dampers but, I also changed it to a Slipper clutch. Bike is fantastic. Love riding it now. This should be sent to all upto 2016 owners with vibrations and noise.
41 - 50 of 50 Posts
