1 - 11 of 11 Posts
XSR900 tall rider mods / tank comfort
Hi everyone - I'm new on this forum and seeking advice/experience from tall XSR900 owners regarding the tank cover and long legs.
I'm a current owner of a R1200R and plan to swap for an XSR900. I've only sat on the XSR900 at the dealer - while feeling generally comfortable at 6'3" and 33" inseam I found my knees were uncomfortably resting on the edge of the scoop on the tank cover. E.g.
For reference, I sat on an XSR700 and it fit wonderfully. Much prefer buying the 900 though.
Anybody else deal with this and/or find a solution? Can the 700 tank cover be installed on a 900? Is there another mod that would bring the seat position back to make more room for knees/legs? I've been lusting after this bike but concerned the standard fit just won't work :/
Thanks!
Jared
A Corbin seat could be a possible solution for you. I heard the seat pushes you back a bit. Maybe someone in the forum with a Corbin seat can confirm.
Discussion Starter #3 (Edited)
Thanks for the suggestion - yes it looks like the Corbin Gunfighter would push the position back a little.
<edit> looks like there is a Gunfighter & Lady saddle too, so I could still have a passenger.
Anybody on here have one installed, or other suggestions?
I have this one that came with my used purchase. Consider selling it as I am a short rider and it sits me up just enough to make me uneasy on certain slopes and slow movements. I can say this, I put 6 hours on the ride up to Knoxville and back today and my ass wishes I had that Corbin seat on instead of the stock brick.
Sent from my Pixel 2 XL using Tapatalk
I'm 6'1" with 33" inseam and had the same problem you're describing. Since I only ride solo, I switch to an aftermarket seat intended for a single rider. That moved me back just enough so me knees now fit the tank perfectly. I also added tank knee pads to protect the custom paint job I had applied to the tank.
Does anyone with Corbin (or other aftermarket) also use the Yamaha OEM rear cowl?
I too have issues with where my knees end up (6'2) and have been looking at options, but many seem a bit too bulbous in the back to allow the cowl to fit over. Let me know! Thanks
I'm pretty sure I've read that the stock cowl and s2 cowl both work with aftermarket seats and tail tidys of most varieties. A quick Google can confirm. Better check just in case I lie
The Corbin idea works with the knee/tank thing. But the bike is so cool, I wouldn't care if I could still feel the tank ridges
1 - 11 of 11 Posts
