1 - 4 of 4 Posts
I have a 80's black.
And wanted to install the Blaze panniers.
But ran into problems.
1. Impossible to remove footpegs. The rear bolts are impossible to move. One would expect the same kay to fit in there as in the front bolts. But no. There seems no size to be fitting.
2. As this is the model with the side panels theses bolts are (probably) not the same as on the other versions. They are longer as the hold the sidepanel brackets. I've included a picture. This means the bolts provided with the panniers will be too short too.
1 - 4 of 4 Posts
