1 - 7 of 7 Posts
· Registered
There's barely any and it might just be old oil from the PO and it's not leaking now (I don't think) but where is/did it come from? Valve cover breather hose? PCV breather hose? Where does it go? And why did oil seep out to begin with? Pics are through the right side of the bike.
Last 2 pics of for chits n gigs cuz she's sexy af... :geek:
Automotive tire Automotive design Motor vehicle Steering part Automotive exterior
Tire Wheel Hood Automotive tire Tread
Tire Fuel tank Wheel Automotive fuel system Vehicle
Wheel Tire Fuel tank Vehicle Automotive lighting
· Registered
So no one knows exactly what it is or where it leads to?
I'm assuming it's the crank case vent that leads into the air box? Regardless I just want to know why I see a little seepage there (oil looks old - not seeping now I don't think). When I get my ECU flashed I will also check the air box for oil/a hose for this if indeed that is what it is.
· Registered
So I think it's safe to assume that my MT09 in a NON-Cali / No Charcoal canister bike noted by the 3 rubber hoses at the counter sprocket (which 1 or 2 of em are lines from the bottom of the tank straight to the ozone - rather than to a charcoal canister)
My question is, seeing as it's a non-California bike, do I still have or need all that SMOG crap? I see the metal smog fittings (I believe that's what they are?) on the top of the valve cover. Why do people do smog delete stuff/block-off plates for this? What is the gain?
And I've verified that the hose in question is indeed the crank case breather that attaches to the bottom of the air box. Not sure why it was leaking a tad...
· Registered
'22 MT-09
The plates over the exhaust side are for pulse air injection for the exhaust. The only real reason to block them would be to prevent popping on decel. The hose for the crankcase breather on the intake side of the cover is probably getting a bit mushy and it's not sealing.
1 - 7 of 7 Posts
