1 - 6 of 6 Posts
I have looked on the internet for over an hour trying to find Speed Bleeders for my bike and I can't find them listed for an FZ-09 anywhere but Stoltec and he is out. If I know the size I need for the front and back if they are different I can order them. I can't find anything on the forum. Please help!
2017 FZ09 has a different R/H side front caliper
Stoltec list SB8125L
8mm x 1.25 thread is the correct thread. The "L" length is a good fit for the front clutch side caliper and the rear brake caliper.
I like the Stainless versions SS8125L but other than material they are the same.
On the 2017 bikes, the right caliper has a different bleed screw, with an O-Ring that I guess is designed to make bleeding easier.
The "L" length speedbleeder was too short for this side and would not seal.
It shows on Revailla parts that all 3 are the same part number.
I just bought these from Stoltec a week ago. They stick up slightly higher than stock but I put one side by side of the stock and they are the exact same length thread wise. I assume extra length is for check valve.
Reveille has them for $7 each or more for stainless.
https://www.revzilla.com/motorcycle/speed-bleeder-for-metric-bikes#skus_tab
1 - 6 of 6 Posts
