1 - 5 of 5 Posts
My bike does a weird a farting type noise when I try to take off fast. I normally ride in A or STD mode and it does it for both. Do any of you have a clue as to what it may be?
wierd.. Try less throttle, more throttle. Try being quicker with the clutch.. See if any of that makes a difference, it would be a big help in getting to the bottom of that noise.
Sounds like too much throttle and not enough clutch- try releasing the clutch just to the point of engagement, then roll on the throttle as you continue to release clutch. Clutch plates like to engage at low rpm, then ramp up from there. If you raise the rpm BEFORE entering the clutch friction zone, the plates spin and glaze as they try to catch up, and that is what it sounds like is happening.
That might be it. I'm still learning about this bike, way different than my r6. I'll try being quicker on the clutch, will report after a few rides.
Reactions: beck
1 - 5 of 5 Posts
