1 - 11 of 11 Posts
I just picked up a brand new 2018 xsr900 today and noticed it vibrates a bit at speeds from 25-20mph when the clutch is pulled in ornits in neutral. It doesnt do it at any other speed.
Any idea if something is wrong?
Sent from my SM-G975U1 using Tapatalk
Congrats on the bike.
Vibrates how/where? Handlebars wobble? Foot pegs? Are you confident it’s only in that range of speed? (odd if so)
Discussion Starter #3
No like a very subtle vibration, like not rough or jaggedy more similar to the engine revving at 2000rpm. At first I thought I had reved the engine slightly every time it happened.
Basically ill pull in the clutch. It'll feel smooth till i hit 25mph, then theres a very subtle soft vibration that can be felt in the footpegs and handlebars. Once i slow down past 20mph it dies off and its perfectly smooth again.
Idk if everything just needs to settle in. I put 200 miles on her just today from cruising around. Didnt really notice it till around 120 miles though.
I would first check the chain tension and make sure it's not too tight. For some reason, the manuals for all of the versions of the 900 triples show a very minimal amount of chain slack, and as far as I'm concerned (along with many other people), it's just not right.
If that doesn't fix the vibration, post a follow-up...
Discussion Starter #5
Whats the right spec?
I iust went outside and checked.. that thing is tight. About half inch of play
I like about 25-30mm of free play on mine. I think the book tells us 10 or 15mm... 😖
Discussion Starter #7
They probably adjusted it to that. I tend to be very paranoid thats why I noticed it. Will wait till 600 mile service to seenif it settles down.
I do remember how tight the chain was on mine when new. Have since checked others on the showroom floors, they all seem to be very tight from new.
A vibration appeared in my bike, at around 5000kms. To my ears ( Mechanic Ears) it felt like a bearing had gone in the Gearbox, It was very obviously a new Rumble/Vibration, as the engine is generally so smooth.
Turned out to be a dry chain...now I can tell when the chain needs lube by this Rumbly vibration.
It immediately vanishes with a good lube.
AB
Discussion Starter #10
AB
I was thinking the chain might be a lil dry. Gonna lube that sucker up
Discussion Starter #11
So I added motul chain oil to it and it still happens. Goes from around 23mph down to 18mph.
1 - 11 of 11 Posts
