1 - 3 of 3 Posts
My friend installed a tail tidy on his FZ and disconnected his rear indicators. He did this by unplugging the factory connector.
We have since installed Hyperlites but cannot get the front or rear signals to work.
The factory harness has a red,black, and black with grey stripe for each side. Anybody out there that can help with our wiring confusion?
Black is ground, the other same color on both sides is running light, and the totally different colors on either side are blinkers. That is what I always go by. You may have blown the fuze under the right side scoop in the fuzebox.
Check that the pins in the harness are in the correct spot. If you think of the flat slot that gets held by the clip as the top; red in top right, black in bottom. I couldn't figure out why my new signals weren't working until I realized the pins for the wires were in the wrong spots for the yamaha harnesses.
1 - 3 of 3 Posts
