21 - 30 of 30 Posts
Discussion Starter #21
So I wanted to ask and see what you all think. The brake and the running light look great on the tail light but the turn is a bit dull. Is that because of the relay I need to put in?
The relay only slows down the led lighting back to normal speed. If yours flash quickly it will fix that.
From what I have seen, that is just the way that light looks. I was considering it, but the color difference between brake and turn wasn't significant enough in my opinion...
Discussion Starter #25
The only problem I've noticed is during the day. At night it's amazing. I might supplement the turns with some auxiliary leds or something.
I was also thinking maybe they're dull because the stock ones aren't LED. The conversation earlier in the thread linked to some adapters for the led conversion.
Discussion Starter #26
Here are the night pictures. I know nothing about cameras but I was able to play with a bit to see the light well.
Camera doesn't capture the difference well. In person its enough to grab attention.
Discussion Starter #27
Decided to supplement my integrated tail light with some auxiliary turn signals. Fabricated some small L brackets and wrinkle coated them. I need to figure out how to make them running lights as well.
Discussion Starter #28
Got the fronts installed. Like the look but they're a bit cheap feeling. Ran out of electrical parts so I'll be enabling the running lights tomorrow. IMG_20150725_150934.jpg
Got the fronts installed. Like the look but they're a bit cheap feeling. Ran out of electrical parts so I'll be enabling the running lights tomorrow. View attachment 19345
Think I would have done them the other way and put the stalk-style signals out back and the multi-directional flush mounts up front. Looks good though!
Discussion Starter #30
Thanks! Didn't like how the flush mount signals looked. They didn't fit the shape of the stalks. I might try it though. Good call.
21 - 30 of 30 Posts
