1 - 6 of 6 Posts
Has anyone looked into putting orange lights into the running lights and wiring them in parallel with the turn signals?
I'm sure it could be done if you wanted it bad enough, but the problem I see with that is the too close proximity to the headlight, making the blinkers too hard to see for oncoming motorists
Reactions: v2Bob
I don't think I would remove the main ones, but I don't think they do a whole lot as they are set up. The headlight is always on during operation right?
I thought about wiring some amber leds into the fake air scoops. That may be a better solution. With the right reflective material, I'm sure you'd be able to have the whole air scoop grill light up. I've purchased the lights and stuff just haven't wired it up yet. Just a thought for you.
1 - 6 of 6 Posts
