1 - 4 of 4 Posts
What is the tightening torque for the stem nut?
And, what procedure for doing it correctly?
Does it need to be tightened in steps?
Does it need to be loosened a bit after reaching the correct torque and then re-torqued?
Or...do I just put one steady pull up to the number and stop?
Page 3-18 of my Yamaha service manual. You should review the procedure 1st before doing that. You should not need to adjust unless it has excess free play or is binding. The lower nut initial torque is 38 and final torque 13 foot pounds.
Maybe someone would be so kind to copy paste said instructions from said service manual?
1 - 4 of 4 Posts
