1 - 12 of 12 Posts
Has anyone found a throttle lock that works on the FZ09? I've had the bike for 2 months (it's my 5th bike) and by far the most fun I've had on 2 wheels!
Thanks
Throttlemeister-heavy, keeps vibes down too.
I had one of THESE on my old bike. Cheap, effective, and reliable. I will probably pick one of these up soon. At $27 shipped, can you really go wrong?
Actually here is a better link on BIKEBANDIT. Speaking of which, are our bikes single or dual cable throttle? I never took notice..
Thanks for the input. I was thinking of the throttlemeister. Nice to know it works. I'll order one tonight.
I completed the installation of a Vista Cruise MCVICY-P which is the model for use on Yamaha motorcycles. This Vista Cruise came with two different clips for use with single and dual throttle cables. However, it is designed for a motorcycle with the cables below the throttle.
The problem with installing these inexpensive throttle locks on the FZ-09 there is nothing to prevent the lock from spinning with the throttle. I modify one of the clips to attached to the one of the screws of the throttle cam housing. This arrangement positioned the lever to the front of the throttle. It worked but all of the bending weakened clip and it broke. The position was not the best.
I fabricated a bracket from an aluminum sheet and sprayed with plastic dip. The bracket attaches to screw under the control module and position the Vista Cruise were it belongs.
The Vista Cruise was purchased here Amazon.com: Sound Off Recreational Vista Cruise MCVICY-P: Automotive
Bracket
Bottom view of the bracket installed
Side view of the bracket installed with Pro Grip 714
Top view of the installation with Pro Grip 714
The finished view
1 - 12 of 12 Posts
