1 - 6 of 6 Posts
Since the weather is still too crappy to ride, I'm spending my time obsessing about future maintenance. For those of you who've done a throttle body sync already, do you need a specialty screw driver to get to the bypass air screws? It's kind of hard to tell from the drawings.
Looking forward to getting a Morgan CarbTune. I've been pretty lucky with my old MotionPro mercury unit on my carbureted bikes but I always felt I was one rev away from blowing mercury out the tailpipe. Superfund site in the garage--film at 11:00!
No special screwdrivers needed.
It's been a while since I did mine, but it was probably a driver about 3-4" long with a narrow blade.
Try a search in this section for throttle body sync. Someone posted a whole bunch of pictures on the subject - took all the mystery out of it.
If you want a challenge though, try it without a guide.
Its easy. Just take your time, you will be fine.
1, Protect the frame from the tank when you remove it.
2, Dont mess with the set screw that was set by the factory.
thanks-done it many times before on other bikes and have the shop manual. Just wondered if there were any gotchas on this one.
1 - 6 of 6 Posts
