1 - 7 of 7 Posts
What say The Collective ?
Does the non adjustable just run wide open and oil thickness not so important ?
Would a person, then, just do the 10 wt on the adjustable side ?
That is what stoltec determined. Just change the oil in the right fork leg for different dampening.
I thought I had read it, somewhere, just wanted to confirm.
May have someone coming in for springs and I may be short on 10 wt.
Thanks, Chris
Resistance is futile. The right side is sufficient for dampening.
The left side has zero damping, just a tiny amount of compression at the bottom of the stroke to stop it bottoming out hard
That would be AIR SPRING....
Disclaimer: not a technical term.
We need more fork choices. Wait and see, some year Yamaha will come out with an R version with fully adjustable front and rear suspension.
1 - 7 of 7 Posts
