1 - 13 of 13 Posts
You sure can.
Always idle/run your bike in a well ventilated area.
What part of MD are you from?
I used to live in Columbia/Baltimore.
Air box MUST come off. Disconnect the breather hoses from the gas tank and rotate it 189 degrees clockwise. Once you've removed the seat. Put a blanket there and rest the gas tank on the blanket.
I found 190 degrees works better in the Southern Hemisphere.
1 - 13 of 13 Posts
