1 - 10 of 10 Posts
I've seen opinions/feedback here and there throughout threads but not one summary topic on the Default Mode. (at least none that I could find with searches)
For those of you who have done the Stoltec ECU Reflash, which mode did you select as the default at startup and based on actual use, which would you select now?
Thanks
Standard as default. It really does not matter. Shut throttle, push mode button once or twice, it's a none issue.
Thanks. I know it's just a quick button push but if folks who picked A mode end up preferring Std every startup, it is just more of a convenience to order with Std mode. Personally, I'm going A mode myself most of the time and don't have the ECU flashed yet. I do have a browser tab up though and am close to ordering and itching to go to the garage and pull it and send it off :)
I chose standard for mine. I ride mostly curvy often rough or slick roads.
Standard is plenty for me unless I'm feeling particularly naughty, or I'm on a really nice piece of road or track.
1 - 10 of 10 Posts
