1 - 6 of 6 Posts
All of a sudden, I am having trouble removing the key from the ignition switch. WD40 helped a little bit but it is still a problem. Does anyone have a suggestion for a better lube - maybe some kind of graphite?
Maybe white lithium grease? Put it on the key and put it in and take it out of the cylinder a few times. I know a new key is sometimes hard to insert/remove because the cut areas are pretty sharp. Not sure why yours would start doing it all of a sudden though.
Be cautious with any greasy type lubes. They'll hold dust and grit in the tumblers. I use white teflon powder from local hobby shop. Graphite's great but can be messy. Dremel tool and wire brush will take any burrs off the key too.
+1 on dry lube.
In a pinch (on a trip?) lightly dust both sides of the key in talcum powder,
shake the loose powder off and try the key in the lock a couple of times.
Always use a dry graphite powder in any lock cylinder. And, never put a liquid in after putting in the graphite powder. The liquid would gum it up.
do you get the same results with the other factory key that came with your bike. Maybe that key will work differently. Try it.
1 - 6 of 6 Posts
