1 - 8 of 8 Posts
did any of you guys have trouble removing the middle spark plug coil
there seems to get a device sitting right on top of the coil
also im pressing the 2 blue tabs in on the fuel line but its not coming out
Once you get the tabs pushed in all the way, it will disconnect with little force.
ok i must not have been pushing them in far enough i just ended up sitting the tank on the seat
but i still need to find out how to get to the middle coil
If my memory serves me right I took off the emission hoses on top of the cylinder to make some extra room. Once you get that out of the way unplug the coil, and gently work it up and out. Flat blade screwdriver with your tongue out to the right side should work.
Time for me to replace mine also.
I followed the tank removal tips on here and had no problem getting it off to have the ECU re flashed.
Guess I'll attempt the plugs soon.
1 - 8 of 8 Posts
