Hello friends. While replacing the clutch basket (and converting the clutch to XSR) I saw a few things I have questions about.
1. Should the oil pump chain be replaced at any time? How do you know she's okay? Is there a time to replace the oil pump?
2. The sprocket moves in and out. Is that okay? (As in the video ..)
www.youtube.com
In the comments they wrote to him that it was okay but I prefer to hear from the friends here.
3. I replace the clutch because there was a phenomenon that the motorcycle was not traveling in gear. Always stays the same as in neutral. I found one broken clutch pad there, and a slightly cracked basket. I bought everything new. Now the question is whether for sure this is what caused it, before I close everything, or could there be something else. I found there how a welded part, I would love to hear what its function is and how it gets to the point where it is welded. Should it be replaced? It's not really expensive, and could it have caused a phenomenon of a motorcycle not traveling suddenly.
Yamaha MT-09 Check Oil pump / Ölpumpe kontrollieren
the workshop manual said the tolerances are OK.
