1 - 8 of 8 Posts
It says "procedure error" when testing. This corrects the procedure for testing.
Didn't know its boosted and has a pressure sensor , air temp yes ,
Measure intake vacuum. Mostly use to tune deceleration and on/off throttle. When I map with the PCV I like to run the Autotune with the psi map for a bit. Smooth things out in the cruising range a lot.
Definitely not a geek.... We measure pressure all the way down to a perfect (impossible to achieve, practiclly) vacuum.
1 - 8 of 8 Posts
