1 - 4 of 4 Posts
Hi, i got a problem with my fz09 2014. I purchased it recently but today i got a check engine on my dash. When i'm accelerating, i can see the check engine (6-7k rpm) and the engine stop running. My error is D1 15. That happened after washing my bike. This is a problem with the throttle position center, someone got the same problem and he changed the throttle body. I'm not sure about what to do.
Sorry for my bad grammar, i'm French.
160448
160449
160450
If the TPS error happened right after washing the bike, you might try removing the tank and removing the plug on the TPS and dry it out and then put some dielectric grease on the contacts.
While I had my tank and panels off recently to clean the air filter, I disconnected as many connectors as I could readily access and applied a little dielectric grease.
19 is the side stand switch ,which makes sense after washing ,hit it with a leaf blower or air gun ,work the switch a few times
1 - 4 of 4 Posts
