1 - 8 of 8 Posts
I want to run some wiring from the bars to the battery area. Most bikes I've been able to snake the wires without lifting the tank. I'm not seeing a clear shot from the front to the battery. Has anyone been able to do this without lifting the tanks. On my S10 the tank hinges toward the rear of the bike making it very easy, but this is a different set up.
Lifting the tank is easy.
I threaded the wires for my heated grips and USB module without having to lift the tank completely- I just lift up the part close to the rider just a bit, run the wires through the frame in front and pull them towards the battery under the tank and through all the other wiring. It takes a bit of patience/focus but it does not take long.
YMMV.
Marthy is right. Pull the tank, and it's easy to run wires inside the frame. It's hollow Back there so there's plenty of room to make a sanitary installation.
1 - 8 of 8 Posts
