1 - 2 of 2 Posts
Hello all i am new to forum i have a graphite fz-09 love it! I ran into a problem yesterday my the ledshon tge tailight that constantly stay on are not working.. my brake lights do work. I am getting no power to the blue wire going to the tailight. Im assuming that is the wire im looking for. Is that wire go to an individual fuse or relay i should be looking for? Or should i take it to tge stealership and. Pray warrenty covers this? Thanks
Check all the fuses amigo... Under seat and under right air scoop... Im not trying to sound obvious but if you've never checked fuses just take them out one at a time and see if the little wire in each fuse is burnt.. If not, its good.. If wire is burnt... Its bad... Or you could use a little electronic fuse checking device.
If its not a fuse... Check the connections from wires
1 - 2 of 2 Posts
