1 - 6 of 6 Posts
Been looking at threads regarding using the ZX-10R Kawi shock on the FZ09. Problem is when I go to ebay and look for 2008-2010 ones I see a couple of different looks. Is 08 thru 10 the correct year?
I do see a new one for $125. I would much prefer to go new.
If someone has a link to the correct shock that is new I would appreciate it. I would hate to buy the wrong one.
Thanks guys.
2008 to 2010 ZX-10 shock will fit. ZX-14 won't work. Most important is the offset canister. If it 90 deg it won't fit... need to be going up at an angle.
You should do some research on spring rates and know what youre buying will be in the appropriate range. Racetech's website will have info on the spring rates and if you search here you will find info on the stock spring and what others have gone with. Good luck. This mod is worth it for sure. I've got the zx6rr on mine. I'm very pleased and weigh 200# with gear.
Daniel
Does it HAVE to be 08-10? Or Will other years fit?
1 - 6 of 6 Posts
