1 - 4 of 4 Posts
So the two main choices from most posts that I've read are the:
ZX6RR 05-06 closest to stock w/ max. adjustability and hard to come by.
ZX10R 08-10 has longer mount length & higher ride height.
Does the 10R have the same or similar adjustability or is it limited like a lot of OEM style shocks?
Has anyone tried a ZX6R 07-08 or ZX9R 98-99 ? I found a chart that had similar specs as the 6RR but I don't know about the adjustability.
Make Model Year shock length shock stroke
Kawasaki ZX6RR 2005-2006 330 +12/-0 mm 63.5mm
Kawasaki ZX6R 2005-on 335,5 +12/-0 mm 64,5 mm
Kawasaki ZX9R 1998-1999 330 +12/-0 mm 69 mm
Any experience or feedback with these or other options would be greatly appreciated. I'm a 225 lbs. ex-racer trying to make some decisions on which direction to go.
Thanks in advance!
D
One of the other options of course is the Penske line of shocks.......three different choices there.
Reactions: cza888
Really want the triple adjust shock and 25mm cartridge front kit from Penske, but just bought the bike and on a budget unfortunately. :(
I had a ZX6RR on my bike. Had it re-valved and re-sprung at Traxxion Dynamics. The stock valving has way too much compression damping.
Recently sold it and got a Penske 8983 from Traxxion. In addition to compression and rebound clickers, the Penske has ride height adjust which I wanted.
As far as performance between the two, there really is not much difference.
I also have the AK-10 fork cartridges from Traxxion. This combo really transforms the bikes handling.
1 - 4 of 4 Posts
