1 - 3 of 3 Posts
I really like the rear handles on the FZ6 (and all other bikes that use them). I'm potentially interested in fabbing a setup that could make them mountable to the fz09 seeing as how there is no real grab handle back there for passengers. But my problem is, Ive never actually looked at them in detail when I had my bike. Does anyone have a bike with them that they could look at and take a pic so I could see what I'm looking at. I'm sure its molded into another part that I would have to destroy. Also what do you guys think of this idea?
Have you seen the rear rack Yamaha sells for the 09? Bolts to the underside of the tail, um, 2 bolts on each side a bit behind the passenger peg mounts I think. You can probably use those bolt locations. If I recall right the subframe is ready for the bolts but you need to drill the plastic.
That would be an awesome set up start. Anyone know what yamaha calls those handles so I can start a search to see what they'll cost?
Edit: Found them. Looks like they might work. Hmmm
Sent from my SCH-I545 using Tapatalk
1 - 3 of 3 Posts
