1 - 6 of 6 Posts
Has anyone done a write-up on doing the gold valve install?
I feel confident enough to do the spring and oil swap but not too sure about the valve changing. I wasn't able to find anything on racetechs website.
Thanks for any info.
Reactions: Davinci
I have done it wasn't too tough but is little technical just have to follow their directions take your time call tech support for any questions I had to make my own spring compressor tool
I have the spring compressor part handled. The 2 main things I was wondering is if you have to slide off the outer barrel of the shock (and redo the seals?) and where are the actual valves located on this picture? http://images.imagessite.com/OEM_IMAGES/yamaha_mc_images/Y14FZ09E26.gif
May be a late response, but just as a warning, you should check out this video. You may end up doing more harm than good when it comes to changing valves as opposed to installing a whole cartridge kit where all the valving is set to the correct tolerances. Really informative quick clip of what can go wrong buy an experienced suspension tech at Traxxion Dynamics.
The valves are inside part #10.
No you don't need to split the forks. Take the bolt (#12) out and unscrew the cap (#17) and the guts come right out.
When I did my Bandit it was very straight forward. Racetechs info is clear, you'll need soft V clamps to hold the valve body and a torque wrench that goes low. I'm not sure about these kits, but the Bandit required a 1mm or less hole drilled in the valve body.
1 - 6 of 6 Posts
