1 - 13 of 13 Posts
So has anyone messed around with a quick turn throttle for the FZ? I know that the different modes change the amount of throttle you get for the amount you twist the grip, but the grip still goes the same distance. I would really like to shorten it up, as it feels like a big twist. Has anyone tried the requisite R6 throttle tube? I might try that.
Basically A mode is a quick turn throttle. Talk with Nick of Stoltec about his ECU flash, something worth doing even if you get a mechanical quick turn, or a power commander etc.
Chances are Nick can customize the A map to be even quicker than it already is for a reasonable cost. Base cost for the flash is $125 including return shipping.
I'd be interested as well in a mechanical quick turn throttle. I made one for my R6 with a section of PVC tube and it works awesome.
Having ridden in a mode briefly (no ecu flash yet) I can't imagine having more power sooner. At that point it'd be quicker to ride a unicycle :)
Hum, well, I guess my problem is this, in A mode power is full at 80% of twist. Problem to me is, you cant hold it there. You have to turn further before it bottoms out. Having a solid feeling of the bottom of the throttle feels good to me. I will email Nick and see what he says, but I will probably just try it also, seeing as they are only like, $15. Might do the PVC thing too, I have that on my race bike and it works perfect.
I will report back.
I did some research, the R1 (04 in this case) throttle is 36.5mm part number 4YR-26240-02. So happens that is the same throttle in the FZ. An 06 R6 is 40.5mm, part # 2CO-26240-00.
So I am going to order one. I think I might hand file the profile, so it is a bit progressive. I will post in here again later.
soo.... what did you find out? did you make the switch? I'm changing my stock bars out and was thinking bout going that route. please fill me in.
All third party flashes will get you quicker throttle response. Only about 75% of your throttle is used with the oem ecu. Flash it an you will see, promise....
Here read this - throttle maps
I have daves flash also and set my a made to quick turn. Holy smokes what a difference. It's incredible and makes the bike feel so much meaner
Speaking of throttle... Has anyone tried the Graves progressive throttle or have a good explanation of what exactly it does?
1 - 13 of 13 Posts
