1 - 20 of 33 Posts
First let start with what you need:
1) EcU flashed with function enabled
2) flash tune harness that's available on their website
3) push quick shift sensor
4) appropriate rods to make it fit
Measure what needs to be trimmed. Put nut on rod tape and mark. I cut mine with a Dremel using a cut off wheel then hit it with a file to dress the threads a bit. The nut being removed will clean the last bit of threads
Reassemble rods to sensor using lock tight. Compare to stock rod instal nut, tape and mark how much to trim from threads.
Trim and dress threads in same manner. Make sure length correct. Lock tight in pic was used in previous step not this one
Loop wire around and zip tie to top and bottom of rod. Run wire through factory loom for the gas tank over flow/vent lines. Plug into flash tune harness and run harness under tank and to area behind tank
Remaining plugs plug between the factory plug for the tip over switch and the actual tip over switch. Unplug factory plug. Plug into one end of harness, plug other end of the harness into the tip over switch. Tuck wires away neatly.
Reinstall Ecu and enjoy clutch less up shifts. I have not tried it yet I will report back after my morning ride how well it works. And maybe have a vIdeo.
Sorry for the upside down pics. I will be putting kits together to be plug and play with rods cut to length and installed on sensor. Not sure on price point but somewhere near $300
I'm old...so explain to me why a person can't do a clutch less up shift without a quick shifter? Does it do clutch less down shifts too?
yep its up on the site, Ive sold a couple of them with nothing but smiles
Akra ordered, when I get it but on and decide dbkiller in or out and I'll send off the ecu.
300 seems expensive, but I've shopped canadian online retailers and it comes in near that, and I have to hit 3 different ones to get it all, shipping will kill that idea. I'll get it from you and have that much less stress. That's just what it costs I guess. I assume there's room in the box with the ecu for free shipping?
Can't wait till spring :)
Gonna do the 120kph 6th gear cruise control, I'm so excited.... can you tell?
I'm lazy and uncoordinated so I don't want to have to move my hands to shift up anymore ;)
My question for discussion however: who will have the faster 0-100 time, the guy with the quickshift or the guy using the clutch?
The guy with the quickest 0-100 is the guy with the most talent.
Discussion Starter · #18 ·
yep there is room in the box to include it with the ecu
Would you happen to have a package that include the flash also? I'm running stock maps with the s1r and I've been putting off on having a flash.
1 - 20 of 33 Posts
