1 - 4 of 4 Posts
Have OES sliders delivered today. What is torque value for both rear and forward engine mount bolts? Also, I've always had a center stand. Is it okay to install one bolt at a time on the side stand?
Thanks!
In my search for sliders, I seem to recall someone saying it was 33 lb/ft - here's a link to the thread
Check the owners manual if you have one, though, just to double check.
I also found 33 lb/ft although I don't recall where. They went in just fine and that felt comparable to the engine bolts I removed, but I only put on the fronts so the rears could be slightly different.
It's no problem on the side stand either. Just do one at a time so the holes stay lined up and you'll be good.
Thanks all….Easiest slider install I've ever done. Can't believe there was no kind of thread locker residue on the stock bolts. Believe all my other Yamahas had some.
1 - 4 of 4 Posts
