1 - 4 of 4 Posts
I understand that a reflash can improve some of the factory restrictions, but do you need an EJK to adjust fueling for exhaust pipe/airbox mods? Thanx-
Depend what you want to accomplish. If you just want to tune the fuel for your exhaust or improve the throttle jerking the EJK controller will do a fine job. If you want to get a bit deeper into it and remove the restriction the flash will be a good option too.
I have 2 controller ready to go.
Is there a reflash available to remove some of the factory restrictions?
Soltec's project thread, he said you can change many factory settings. Fan turn on temp, speed limiter, also mapping changes. He said it should be available soon.
1 - 4 of 4 Posts
