i think that the XSR bars are black and the same bend as stock. Rizomas highest bars will be very close.
i think that the XSR bars are black and the same bend as stock. Rizomas highest bars will be very close.Sorry guys , but i have searched everywhere on this forum .Does anyone know which pro taper bars, countour or evo is closest to OEM height/sweep/rise..
I cannot find the info anywhere.
All i find is carmichael and that is lower and more forward. I think for me the stock height is perfect. and i want to change the colour of the bar but not affect the position too much.
thankyou
thankyou, would you know where i can find the actual measurements of the OEM bar, Has anyone measured it on the forum?i think that the XSR bars are black and the same bend as stock. Rizomas highest bars will be very close.
OK, but you can compare the info Rizoma provides about the bar dimensions that you can use to find bars that are very similar.thankyou, would you know where i can find the actual measurements of the OEM bar, Has anyone measured it on the forum?
Unfortunately rizomas highest bars dont come in blue...
i thought about it, too much trouble, the durability of anodizing aluminium is by far the best so ill go for a known brand..Paint the stock bars
I will do it and will compare to my stock bars tomorrow. i think Rizoma will be the choice , thankyou.OK, but you can compare the info Rizoma provides about the bar dimensions that you can use to find bars that are very similar.
Thanks for measuring.I did a few measurements, the OEM bars have a 40mm rise, and 50mm sweep. 720mm wide.
The measurements are a rough idea, so the closest in
Protaper are
Carmichael, Blue, Width 800mm, Height 77mm, Rise 40mm, Clamp Area 195mm, Sweep 55mm, Control Area 180mm
these are actually closest to OEM. Ill be getting the Carmichaels after all.
This is the MA011 bend, which is quite aggressive. Just for comparison if it helps. Not sure if it does, but why not.Its unfortunate Rizoma website does not add the SWEEP of their bars.( they use and angle ) I would have to use Pythagoras theorem to figure out the sweep using their drawings...
yes you are correct the sweep is aggressive. 80mm..This is the MA011 bend, which is quite aggressive. Just for comparison if it helps. Not sure if it does, but why not. View attachment 175374
Ah, you got a different bend than I did.I posted a photo in another thread with Rizoma low bars (MA006B) with the stock bars and the sweep is almost the same.
post 13951.
What have you done to your bike today?
This is usually a very popular daily post. Just pass the 600 miles mark over the weekend... 2nd oil change done! :cool:www.fz09.org
I plan on bringing my FZ to the ECR, you'll have to try my MA011 bend to compare. I'm curious if I/you can tell the difference. They seem so similar. It might be the better compromise in height vs. touching the tank or not.I just rode with my new Rizoma bars. I am a happy man with exception of losing abil to tarn the bars to the stock steering stops. I just have to get used to it.
