1 - 3 of 3 Posts
Hey guys I have never used a power commander before. I got a good deal on it and I want to use it so I can install some mods on my MT-09. I was wondering if any of you could recommend a fuel map for the following mods.
M4 Full System Exhaust
Smog block off plates
K&N Air Filter
Air Box Snorkel cut
Did you already checked the PC website? They have a "pre-cooked" maps available on it. Depending on if you have also the auto tune module, that maps can help you. If you don't have the module,well you have to modify a little the maps. But in any case PC map is a good base to start from.
Inviato dal mio MI MAX 3 utilizzando Tapatalk
Just checking that you are aware that ECU flash is the most direct and arguably the best way to go to get desired results. Not to mention world's easier...
Reactions: shamrock
1 - 3 of 3 Posts
