1 - 5 of 5 Posts
I installed the Graves Block Off Plates today. During reassembly I've noticed there is no washer on the brake side upper radiator mount. The clutch side has a washer, but also has a bracket there. On mine there is a good bit of road grime on the grommet where I feel the washer would go, so I believe there just wasnt one there. However it just doesn't seem correct.
Can someone look to see if there is a washer there? Or post a picture?
Thanks!
After looking at mine, looks like it was done that way to protect the wiring harness from chafe. If a washer was there it would most likely cut into the harness.
1 - 5 of 5 Posts
