1 - 2 of 2 Posts
So, I put the EJK Fuel controller on my bike after adding the M-4 pipe. My questions are how do i plug the pair valve real quick without ordering block off plates and also, now that i have the EJK controller, should I disconnect the O-2 sensor and just let the Fuel controller do it's job without the o-2 sensor getting in the mix?
Any experienced help would be appreciated. thanks!
You can't disconnect the o2 it will not run right.
left side of air box has large hose you can plug. I used a vacuum cap from help section at auto zone meant to cap 3/8" just push it into hose with 1/4" nut driver or screw driver and hook hose back to air box plugged.
1 - 2 of 2 Posts
