i would say there is at least a decent chance the throttle lock caused it
see if it comes back
it should be in intake categoryWhat category is the TPS part located in the OEM parts cat...the throttle body?
Rather you than me. I'll never use anything that controls throttle movement. I do use one of those devices that the heel of your hand rests on to give a bit more leverage and relax your grip.Its called a go cruise by brand, its a manual way to lock (thumb tightening screw) the throttle when cruising and simply push grib forward to loosen.
the slight issue i have with them is when using the front brake (if the go-cruise is too tight) it may cause friction on the throttle grip, and causes the throttle to not fully close, and be slightly open
yes thats a cramp buster, i use that also.Rather you than me. I'll never use anything that controls throttle movement. I do use one of those devices that the heel of your hand rests on to give a bit more leverage and relax your grip.
Hey I dont have the service manual, can you possibly send a PDF on that section via direct messsage?That code is specifically for the tps sensor on the throttle body. The bike also uses an accelerator position sensor in the r/h grip assm. I would follow the repair procedure in the service manual to isolate what is setting this code. It basically uses a pair of sensors to cross check-if they don't match it will set this code.
update...After erasing the code. It stayed clear for roughly 1,000 miles, then came back on, Cleared again. And now pending to see how long it stays cleared.That code is specifically for the tps sensor on the throttle body. The bike also uses an accelerator position sensor in the r/h grip assm. I would follow the repair procedure in the service manual to isolate what is setting this code. It basically uses a pair of sensors to cross check-if they don't match it will set this code.
Sorry, I don't know. But one way to tell is to remove the throttle device and see if the code pops up.yes thats a cramp buster, i use that also.
But as mentioned, ive used the throttle lock on my last 6 bikes and never once acquired a code 2135 regarding this tps sensor. Would a previous ECU reflash from the warranty recall, cause this code p2135?
I just got a check engine light on my 2021 MT09 the other day. Bike is just over one year old, 6200 miles, I’m the original owner. Only aftermarket on the bike is Mivv XM5 exhaust, usb charger wired into extra port behind headlight, and the TST taillight.update....it is not the go cruise lock... the EL light now comes on every 30 miles.
symtoms of spuddering throttle response at 3500rpms, or a slight hiccup is noticed at cruising speed.
There's an extra port behind the headlight?, usb charger wired into extra port behind headlight,
Yes, two I think. It’s where you run the power for heated grips if you had them. I wired my Quadlock USB charger to it.There's an extra port behind the headlight?
Tell me more about this hidden plug...Yes, two I think. It’s where you run the power for heated grips if you had them. I wired my Quadlock USB charger to it.
