1 - 7 of 7 Posts
Hey guys - I didn't see this mentioned in other threads so figured would ask. I was on coremoto's site about to order SS brake lines and got a little confused re the length...it seems like you can order any size you want beyond stock. Is there any reason for needing anything longer than stock?
Thanks!!!
Not if you have stock bars and brake master cylinder- stock length is perfect. I have a Core Moto set, and they are great!
If you're running clubman bars with the R1/R6 master cylinder, what lines should you order?
Thanks!!!
Hey guys - thanks for the quick responses...I am running stock stuff so should be good to go w the std length!
1 - 7 of 7 Posts
