1 - 13 of 13 Posts
I had my headlamp out last night and noticed the part pictured on the ground this morning. Can anyone confirm if it is part 15 from the diagram?
Thanks guys!
I don't think so.
They don't tend to fall out of rubber bushings easily.
I think it came out of the lower bolt (not pictured).
Gimme a second to look up the number...
I suggest you look at your bike to look for missing parts. That is more likely to result in the true answer to your question than asking the forum.
It's late though :-( I thought I'd see if anyone else has seen this drop out so I can focus on getting this in the right spot without all the other collars falling out :)
Ahhh young grasshopper, watched every sunday as a kid
Reactions: DNFDOUG and v2Bob
Probably should have just used a reference to Master Oogway from Kung-Fu Panda
The hex bolt that holds that in fell out of mine, I had to go to ace to find a replacement...ended up having to buy a SS bolt and a washer because I couldn't find a big enough button head
it's probably the one for the bottom bolt. falls out on me all the time when removing the headlight side cover.
1 - 13 of 13 Posts
