1 - 9 of 9 Posts
This is why I can't have anything nice.
I was doing the 8000-mile service (at 7000 miles,) about to synch the throttle bodies, when I knocked the gas tank off the bike. The impact created two smallish dents and one ugly, medium-sized one, which was almost enough to make me burst into tears by itself. What really made me queasy was the fuel pump: the hose connector snapped off the plastic spigot, and it's all a unit construction. A new pump from Cheap Cycle Parts is about $260.
Sorry. Had to vent. Thanks.
PDR to get the tank fixed. Sorry this is a major expensive for you. You did well to go with a bike under $10K. My last BMW cost me $26K, and I only was able to sell it for $15.5K used after two years. Toys are expenses that we should only buy what we can afford to have and maintain. Good luck with keeping yours looking and running well.
Thanks for the Parts Shark heads-up, DR. The expense is irritating but not crippling. Mostly I'm just sick at myself. I mean the thing is only seven months old. I'm as-we-speaking trying to repair the broken fuel pump spigot with JB Weld, but I give it only about a 20% chance of working.
I wouldn't experiment with a shade tree fix on the fuel system.
Buy the part, rub out the tank, ride on. It does suck, you just dented the banks motorcycle, wisdom (sometimes) comes with age.
JB Weld claims to be suitable for gas tank repair. My main doubt is its adherence to plastic. It'll have had 24 hours to cure when I get home, so I'm going to test it by trying to break the thing off. And if it doesn't come off in my hand and it seems to be air-tight... I'm still going to buy another pump because this fix is just too sketchy.
1 - 9 of 9 Posts
