I am currently running Yamalube 4T HD 10W-40 but will change to Motul 300V 10W-50 next summer. What are you preferences for the CP-3 engine?
Fair point. As long as it's API service SG type, JASCO standard MA it doesn't matter what you put in and it works for you.Oy vey an another black gold thread! 🫠
I can tell you for a fact that's not the case with some bikes I had!Fair point. As long as it's API service SG type, JASCO standard MA it doesn't matter what you put in and it works for you.
Maybe but these standards are pretty exacting and that's why they exist.I can tell you for a fact that's not the case with some bikes I had!
Interestingly, Castrol have 5W40 on their recommendations Castrol oils and lubricants for your YAMAHA [4-Stroke] MT-09 (2014-2022),Been in contact with Castrol asking what oil they recommend for the Yamaha mt 09 2014. They sent me an e-mail with different oil that follow the above mentioned specifications. I also asked if I could run a 5W40 oil during winter, to that I got no answer.
Anyone know if this would cause any damage to the engine?
/Thanks
To say the least! They sent me a Pdf with a lot of options, but no 5W-oil.Interestingly, Castrol have 5W40 on their recommendations
Got an answer from Castrol saying this homepage is for Australia only, and that it differ between countries. Anyone with an Australien manual that can confirm this 5W40 is recommended?Interestingly, Castrol have 5W40 on their recommendations Castrol oils and lubricants for your YAMAHA [4-Stroke] MT-09 (2014-2022)
No. A lower xW number is better for sub freezing temps. It's a rating based on cold cranking tests.Been in contact with Castrol asking what oil they recommend for the Yamaha mt 09 2014. They sent me an e-mail with different oil that follow the above mentioned specifications. I also asked if I could run a 5W40 oil during winter, to that I got no answer.
I get the basic principles of engine oil. But, my thinking is that oil threads like these are percieved as useless because there are to many opinions and no facts. Impossible to draw conclusions. Thats why I contacted Castrol. 🤓No. A lower xW number is better for sub freezing temps. It's a rating based on cold cranking tests.
They're also a company, that's why you got an ass-covering response, lolThats why I contacted Castrol. 🤓
No, it won't do damage. The number before the W is only for subfreezing temperatures. I assumed you knew this, since you said you got the basic principles.10W. What I dont get is why a lower W-value would matter at all: If you run say a 0W-40 in Summer instead of a 10W-40 would that do damage?
So a lower W-number is always better?the W number is irrelevant.
