1 - 7 of 7 Posts
I want to know, before I install the shock, what i need to do for my weight im 185 gear up and i don't do track
Thanks for your help
Envoyé de mon iPhone en utilisant Tapatalk
I had a ZX6RR on my bike before I got a Penske.
I sent it off to Traxxion dynamics for revalve and overhaul.
My riding weight the same as yours. The shock with stock valving and spring is way too stiff IMO. Traxxion reduced the damping by about 50% and installed a 550 pound spring which really helped.
It won't cost you anything to install and try it out. If you don't like the really stiff ride send it to Dan at Traxxion. They have all the numbers from doing my shock.
Good luck.
set all the damping settings to "soft" and then adjust to your preference; do a forum search for sag setting and set this first.
Reactions: Tigershark
1 - 7 of 7 Posts
