1 - 3 of 3 Posts
Have the above setup need a good ECU flash any advise for the above setup that would removed top speed restriction
Vcyclenut has a flash with an ignition map, fuel map, smooths throttle response, and it removes the speed limiter, for $180. It also includes quick shifter capability. All specific to the Akra Carbon. You probably won't even need the Bazzaz. For $180 you can do it all, and then some.
I went with Vcyclenut and I have the Akra Carbon as well. Very pleased. The speed limit is removed and with the 80% turnabout throttle on A-mode...the bike is a beast!
1 - 3 of 3 Posts
