1 - 10 of 10 Posts
My bike is leaking oil. We rode about thirty-five miles and left the bike for about an hour. When we got back to ride, there was a small oil pool, about two inches across. This is the second time this has happened. Has this happened to anyone else? I don't know where it's coming from. Any suggestions? Thanks, guys!
There should be some signs of where its coming from.....can you get your head under there and look?...
There are a few common places it can come from.The oil filter,oil cooler (next to the filter) ,drain plug - any of these not installed correctly.Loose or stripped threads.
The output shaft (counter shaft) oil seal is damaged.
The clutch cover,right hand crankcase cover, the alternator cover or the oil pan - any of these has a leaking gasket.
Sometimes a leak can make such a mess that it can be hard to pinpoint the source. If there is oil in several places, clean everything up as best you can and then ride the bike for a bit and check again.
Keep a close eye on the oil level and top off as necessary until you can determine the source of the leak.
Positive it is not excess fuel form the vent lines? Did you visually inspect it to make sure it is oil? If there are no visible spots on the motor weeping it could also be chain lube/grease that breaks down when it gets real hot outside and drips. Where is the spot showing up when the bike is parked?
I recently had a puddle of gas but thanks to the forum I found it was from those lines... Hopefully yours is the same Jen. Like you said, it isn't a harley
Mine has a very small puddle under it after it sat in the hot shop for the past week, maybe 2" wide and the hubby said it was from the vent tube
if you can't tell where the oil is coming from, clean the bottom of the engine really well, and dry it thoroughly. Then take a can of tinactin, or some other kind of athletes foot spray, and spray the bottom of the engine until it's white all over. you'll be able to tell where the leak is coming from soon enough.
This is oil. I didn't notice it in my garage. Both times were in a parking lot, after we walked around for a while. I'll look at it again tomorrow. I couldn't tell where it was coming from in the parking lot. I'll see if anything is wet tomorrow on the bike.
1 - 10 of 10 Posts
