You obviously know better than the tyre designer.
After reading the post in the link I posted,I tried various pressures in the PR2s on my 1250,measuring the pressure rise from cold.I found 42psi gave the correct pressure rise.Indicating the correct operating temperature.Lower than 42 ,within reason, gave lower operating temperatures.None of these pressures had a noticeable effect on harshness.
Seems Michelin knows what they are talking about when it comes to tyres they designed.
Sir, you can run ANY pressure that you want in your tires. I know what works and what doesn't, and don't really care what some engineer says. My first priority for every tire that I run on my street bike (FZ09), my other street bike (ST1300) and my track bike (600RR) is the ability to stick in the corners.....and 42 psi on some of these tires will not allow it to flex enough to heat up and stick for my type of riding......it's that simple. We all have different needs for tires....some like the long mileage and don't ride aggressive enough in the twisty stuff to worry about the tire sticking well. Others of us depend on a tire's ability to stick well in a corner and damn the mileage. You do what works for you and I'll do the same.
And on a side note, I run my Pilot Road 4s at 42PSI on the ST1300. It weighs 720lbs and between my wife and I riding it two up about 99% of the time, plus a top box, plus rain gear and an air compressor, the total weight is right at 1100lbs, so I run that high of a pressure. On the other end of the spectrum, my track bike is wearing a set of the Michelin Power Cup tires. Front is set at 29-30 cold and the rear is set at 22 cold.........that's right, 22psi cold.
I've been running Michelin tires on my street and track bikes for approx. 8 or 9 years and my go to guy for anything Michelin is a fella names David Grey........Sportbike Tire Service, east coast distributor of Michelin motorcycle tires........and he does know a thing or two about real world pressures and what works.
